RE: Multiplex Magister RTF
Hi fellas:
could you tell me what you think is the "best" kit to upgrade this plane to brushless/esc/lipo???
I've been flying the Magister stock along with my Hangar9 Alpha Trainer with glow power. I find the stock setup to be very overheavy and underpowered. I've already read Greg Covey's article which required different pieces from different manufacturers. Isn't there a one box solution???
As to the kits for upgrade ... I've seen several and wondered which is the best fit and would require the least amount of adding new plug ends etc which would require soldering. My solder skills aren't up to snuff.
Thanks for any info you might have.
