RCU Forums - View Single Post - DP planes Extra or Edge
Old 05-09-2003 | 10:17 PM
rongreg13's Avatar
rongreg13
My Feedback: (129)
Default DP planes Extra or Edge
I've got a DP Edge w/ a Brison 2.4 gas w/ 20x8 prop, Futaba 9252 digitals, and it weighs in at 14 lbs even. The plane needs to be balanced almost an inch forward of the recommended CG to make it flyable. Once you do this, it is a very docile plane. Mine floats to a walking pace for landing and is rock solid stable in flight. Once you increase the throws on the control surfaces and crank in the expo, it will do just about anything you want. I'm still fine tuning the balance and fuel tank location in mine, but already it is a real joy to fly in any mode of flight. The 2.4 will allow it to hover at less than 1/2 throttle and climb vertically at just over 1/2 throttle. You need to have good throttle and speed management with this airplane as its Vne is fairly low due to the oversize control surfaces, but as long as you keep things at a conservative pace, it is a great plane. I'd recommend it to anyone.
I've got a few pictures of my planes in the early stages of construction in my gallery.
