RE: Eagle50
Usually on the sticker or somewhere is the tag 370 D...
So if you see that it should be ok but I can't promise you.
The pinion gear might be different.. the Bee says 9 teeth..
My motor has 10 teeth. You can get a bad lot of motors...
I usually buy 3 or 5 at a time, and I've some that seemed
not as good than others... mind you I have bought from many
different suppliers.
Try to buy from a different supplier and maybe try a Walkera 22e motor hm-22e-z-17
if you are having bad luck from your guy with those motors.
And just so you know if you haven't read, hovering takes the most energy
except for coming backwards tail in.
You need to let your motors cool off between flights... touch the motors
and you will see if they are hot.
Good luck.
