RE: Webra 15cc P5/Speed-P5/ Performance
NIK Your assuming that the computer prop calculator is 100% accurate- which it is not, and no engine manufacturer max RPM was ever hit by the recommended prop. In case you were to put a very light load or overly small prop on that engine it is warning you to limit RPM to 16,000 so it won't break a con rod or loose a bearing. More and more prop recommendations are done for noise levels and not the most power or speed.
