ORIGINAL: xargxar
My pitch curve is 100-90-80-90-100. I'm just not sure if it was a pilot error... should i have switched from full positive pitch to negative so quickly? I'm setting -10ยบ and +10 this time and making sure with the pitch gauge.
You should be able to pile on negative pretty rapidly without a problem. I use vertical pitch pumps to chack the tail setup, and I've slammed in negative on mine, inverted with way too much cyclic, and never hit the body. It's an aerobatic mini so it has to be able to perform this way.
