RCU Forums - View Single Post - Scratch Build - 29" Balsa Stepped Cat
Old 05-04-2008 | 02:17 PM
  #101
detox's Avatar
detox
Default RE: Scratch Build - 29" Balsa Stepped Cat
Spraying the thin CA will take your breath away literally, so spray it outdoors. After applying your thin fiberglass cloth with 3M spray tack adhesive spray on the CA using your paint sprayer much like paint (CLEAN GUN WITH ACETONE AFTERWARDS). The capillary action of the superglue with make boats surface very hard so make sure surface is smooth because it will be hard to sand afterwards. Fill, prime, sand, then paint.
