RCU Forums - View Single Post - MVVS 26 ignition question
Old 05-06-2008 | 09:41 AM
tkg
Default RE: MVVS 26 ignition question
The RCEXl will be timed wrong if you install it on the MVVS factory mount. You can grind off the Mvvs mount and move the sensor so the the timing is correct. Then drill and tap new mounting holes.
