MVVS 26 ignition question
My Feedback: (42)
I can't seem to find anything on the dual magnet system installed in the MVVS26. Do all MVVS26 engines come with this? One is south pole the other is north. Mine comes with the new ignition system.
How does this system work and will the rcexl system work as a plug and play or does the timing need to be readjusted. Thanks
WY
The RCEXl will be timed wrong if you install it on the MVVS factory mount. You can grind off the Mvvs mount and move the sensor so the the timing is correct. Then drill and tap new mounting holes.
ORIGINAL: Skypilot_one
I think the two magnet setup prevents the engine from running backwards.
Mike
the magnet are 180 degrees but when it is at tdc the other magnet is opersite so i used a hose clamp and set it at 30 btdc opersite the mvvs mount witch is the i think the north one anyway works great and is lighter fly upside down allthe time
