RE: Enya SS25 over heats & quits
Run the crud out of it, under-prop it for about the first 20 minutes.
The flight situation might be foam occuring sometime during flight.
You can find out if that is the case by going up in prop one size and trying again (key here is just changing the rpm peak).
