RCU Forums - View Single Post - WANKEL
Thread: WANKEL
Old 05-07-2008 | 11:14 AM
Motorboy's Avatar
Motorboy
Default RE: WANKEL
PoormansACE
2:AA castor builds carbon deposits, and gums up.
Answer:
When the engine is not to be used for some
months (for example, as between flying
seasons), a worthwhile precaution is to
remove it from the airframe and, after
washing off the exterior with alcohol (not
gasoline nor kerosene), remove carefully the
carburetor with intake pipe, glow plug and all
silicone tubing and put them safely aside.
Then, immerse the engine in a container of
alcohol. Rotate the crankshaft while the
engine is immersed. If foreign matter is
visible in the alcohol, rinse the engine again
in clean alcohol. Finally, shake off and dry
the alcohol ,and inject some after-run oil in
the glowplug hole and rotate the crankshaft
several times by hand.
Reinstall the carburetor with intake pipe and
glowplug on the engine and keep it in a dry
place after putting in a vinyl bag.
1: there have been many improvements in synthetic oil technology. like everything else, its an ongoing evolution, and todays "best" is tomorrows "runner up"
3: modern synthetics are much better lubricants than AA castor.
Read here: http://www.modelenginenews.org/faq/index.html#qa5
Important to prevent lean out the engine!!!
Do not close the needlevalve and mixture
control valve too far as this will cause a lean
setting and over heating of the engine. This
can, in turn, create nitromethane oxide
leading to internal rusting of the engine.
Always adjust the needlevalve slightly on the
rich side of peak rpm.
Do not leave unused fuel in the engine at the
conclusion of a day’s flying. Accepted
practice is to cut off the fuel supply while the
engine is still running at full throttle, then
expel as much fuel residue as possible by
turning the engine over 5-10 seconds with
the electric starter. Finally, inject some afterrun
oil through the glowplug hole and turn the
engine over several times by hand.
