RCU Forums - View Single Post - Syclone PRO problems
Old 05-07-2008 | 01:54 PM
AllAboutFunHobbies's Avatar
AllAboutFunHobbies
Default RE: Syclone PRO problems
if i'm not mistaken you haven't lost the needle you just don't know where it is? The low speed needle is located where the throttle linkage connects to the cab, if you look on the side of the throttle linkage arm on the carb you will see a straight end screw head, that's the low speed needle it should be pretty much flush with the carb arm housing.
