RCU Forums - View Single Post - planes and parts
Old 05-07-2008 | 03:15 PM
warrath blacktiger
Default RE: planes and parts
thanks guys wing span is 81 in and len is5 ft 21/4 in long
as for freq i think its 72.5 theres a diod or somthing thats pluged in up at the top on the back i figured it had to do with the freq and how u changed them
i will get that number down had it on disk to bring up here to libary put must have left it at home
as for the ailerons thats what i thought that they where mounted there becase there is a duel lead that runs to both from the center of the wing
and it looks like there are 4 screw holes to hold each plate in place just need to figure out how they where orintade in side the wing and which way the cable goes to each aileron
any thoughts on if the are used together like flaps for takeoff and land or independant for turns and stuff????
and since there is a single plug in lead that goes from the wing to control both what would i need there to contorle them???
thanks agine for all the help and info!!!!!!!!!!!
