RE: Trainer cable between two 12FG's
You need to make sure the student transmitter operates the model the same as the instructor's transmitter. Differences between the transmitters will mean that there will be slight differences in ATV's, trim settings, sub-trims, and so on. You have to set the transmitters up so that the controls on the model operate correctly. Making the transmitters have identical numbers in their programming is a start, and you fine-tune from there.
