Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Trainer cable between two 12FG's
Old 05-05-2008 | 08:22 AM
Default Trainer cable between two 12FG's
I bought the special cable for use between two 12FG's, and it works, partially.
On the trainer side I don't get the same trim settings and functions like butterfly/crow as the teachers model is set up with.
I have tried all the varables, func, mix,normal, on each channels. (8ch RX and PPM)
What can be wrong?
Stein
Norway
Old 05-09-2008 | 11:09 AM
Bax
Default RE: Trainer cable between two 12FG's
You need to make sure the student transmitter operates the model the same as the instructor's transmitter. Differences between the transmitters will mean that there will be slight differences in ATV's, trim settings, sub-trims, and so on. You have to set the transmitters up so that the controls on the model operate correctly. Making the transmitters have identical numbers in their programming is a start, and you fine-tune from there.
