RCU Forums - View Single Post - Twin Otter 125inch wingspan
Old 05-09-2008 | 01:15 PM
AhmicAir
Default RE: Twin Otter 125inch wingspan
John,
I really like the look of your fuse so far.
I have been trying to find a good replica of the Twin Otter and from the looks of yours the shape of the fuselage is quite nice. I would like to see what you do for window angles and a nose section as I find this is the area that most of the plans and the ARF kits have failed in. The nose sections start looking like a dornier, the cockpit side windows on some wrap around instead of being flat and on others the windows are tilted back like what you would find on a C-208. The best look I have seen so far has been Mathisen's setup.
Are you going to make your plans and notes available for purchase?
I fly the twin otter for a living and would like to make a model that closely represents the aircraft that I go to work on. I would like to have it set up to fly on skis as I figure break-up and freeze-up are the only times of the year that I really have time to play anyway. Our summer float season is very busy. I would like to put the short nose on as I prefer it over the extended nose that is seen on most replicas and commuter versions of the twin otter.
Keep up the good work!
