RE: the hyper st PRO thread!
hi guys,i noticed that at full turn the wheels are rubbing on the arms.should i use the extra set of hubs,i believe it will offset the wheels a few mm.the extra hubs have the pin hole closer to the edge,i tried it on but i have to shim it to get rid of the play.so which hubs you guys are using.thanks
