RCU Forums - View Single Post - Mini Titan thread
Old 05-11-2008 | 10:50 AM
  #352
osterizer
Default RE: Mini Titan thread
ORIGINAL: Friday_2006
1. Mini Titan E325 + Motor + Esc : 199,00
2. Spektrum AR6200 receiver : 79,00
3. 3X HS-65MG : 3X32,00 OR 3X S3153 : 3X33,00 (S3153 is a str8 fit i think)
4. Futaba GY401 Gyro : 119,00
5. Futaba S9650 tail servo : 62,00
6. JR X9303 with 2,4Ghz Module : 420,00 ( i have this already)
7. FP 2500mAh 25C 11,1V 3S : 89,00
Sounds like a good starting setup. Where the servos are concerned, yes, the 3153s are a bolt-in job with no mods, but they're a fair bit more expensive than the Hitecs- you ought to think the 3153MGs, and they're something like $40 apiece compared to the $32 you listed for the 65MG. As I understand it, the fiddling required to use the 65s isn't all that much and shouldn't put you off.
You would be wise to factor in a couple extra sets of main blades, and yes, I'd forego the higher-spec version in favor of a nicely stocked parts bin for crash repair. We've been over the question of what spares to get a couple of times. Where the mains are concerned, I would get some Align Pro 325 woodies for training, not more of the TT ones, but your choice.
You might also think of a different motor. If the kit you're talking about is the Ace one with the Ripper OBL motor, then the ESC is a good starter unit, but the motor seems overtaxed in the MT. If it were just me, I'd get the no-electronics version of the kit, then add in a 35-40A ESC and a Scorpion HK 2221-08 with a 10T pinion for a starter setup. It'll come out a bit more cash, but a lot better gear.
