RE: Eagle50
Kolls, I just checked out your link. That setup is similar to the setup I have put together. The motor I got does have a fan attached which hopefully will help in cooling. Be advised though, you will need to build a harness to connect the battery, receiver and ESC together. The connectors are readily available so that should not be a problem.
