RCU Forums - View Single Post - Piston Damage
Old 05-14-2008 | 03:03 PM
  #134
DarZeelon's Avatar
DarZeelon
Default RE: Piston Damage
Plugin,
Since in most engines aluminium parts do not participate in direct mechanical work, against other parts (except the very hard high-silicon piston), it is quite unlikely for aluminium parts to start floating around in the engine.
The back-plate may come into occasional contact with the crank-pin, but this will at most cause a swirl-pattern on it - not major shard separation...
