***OCM KAOS DT-19 BUGGY THREAD***
Has anyone seen the OCM KAOS DT-19 buggy yet? Just got some of them in and they are really impressive. Come with all captured hinge pins and also ALL captured steering rod linkages (both sides) and also upper rear arms are captured. Inner hinge pin braces are about 7mm thick! Also all driveshafts and axles are made of spring steel. Comes with a THICK body stock and not a flimsy one also crimefighter design tires and high downforce wing. Radio box is 2 seperate compartments and fits real tight. Kit comes about 80% assembled, even the shocks but you just have to put fluid in them. Includes clutch bell, flywheel, aluminum clutch shoes, air filter and pipe springs. All CNC alumimum and also captured rear hub lower pins. Steering knuckles have 2 settings for adjustments to. Here are a couple pics I found online but will post my own pics soon.
