RE: Problem with engine tightening up!
Maybe the front or rear bearing is not seated in its bore properly. I have had this happen before. Try installing the prop as if you are going to run the engine and then heat the entire engine with your heatgun, the case will expand and the bearings will move to wherever they should be seated. If this don't work, I would suspect a crank spacer missing or a improperly machined case for starters.
