RCU Forums - View Single Post - Problem with engine tightening up!
Old 05-15-2008 | 09:44 PM
MrMotor
Default RE: Problem with engine tightening up!
Some Supertigre engines used a washer on the shaft that sat right behind the front bearing. One side is flat and the other has a taper on the hole that faces the larger shaft side. Usually the washer was made of aluminum and a few were brass. The washer takes the side load off the rear bearing and prevents the bind you have when you tighten the prop.
