ORIGINAL: bullyhys
YHR,
Yes the Blaster will work with just the booster, but the engine startup I think goes to a default startup sequence .
In otherwords it will start when you powerup the tank, and you my not be able to do a engine shutdown from the radio.
Everthing else will work as it should, the TLS does handle the gun fire, gun movement, turret movement and engine start/stop, and lights.
bullyhys
Hi,
Yep, i can confirm wath Bullyhys said, just tested it.
But you could rename the soundfiles for gun and mg to "user1" and "user2" then you could use channel 5 or 6 to trig them
EDIT. Sorry, forgot to mention, this is not possible if you use HL radio
Regards
Jake
