Converting a Homelite 45cc??
Hello Frank, Theres not really much more to it than that. You might want to remove a little extra material on the carb manifold. If you have the new style Jim has come up with a good idea for replacing the rubber connector. If you buy a conversion kit from RS Engines it will have the prop hub assy. and the mounting tabs needed to mount the engine
