RE: Charger
The minimum discharge rate of that charger (1.0 amp) is higher than what is used for routine battery maintenance. Check the battery (feel) for overheating when you discharge.
Besides performing every step, precaution and detail necessary to prepare your aircraft for flight...before it first leaves the ground , check the battery!
