RCU Forums - View Single Post - Surface drive?New Scratch build
Old 05-19-2008 | 12:31 AM
kajabbi
Default RE: Surface drive?New Scratch build
I plan to build the boat out of Balsa or Ply and then use epoxy resin. Not sure about plans in particular. Maybe around 24" deep v.
Any suggestions? Similar shape to the Supervee 27 but not so long. At least something to suit surface drive which i plan on using.
Also i know nothing of building with fiberglass, only that you need a mould. What is the process? is it easy?
I am pretty new to all this so just assume i know nothing :-)
