RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 05-19-2008 | 02:36 AM
  #1838
wavy777
Default RE: DL-50 engine
ORIGINAL: rcguy!
ORIGINAL: Rush7
T.Edney the DL 50 will be a perfect match for the EF Extra 300. I put my trusty DA on the front of my Extra when I first got it......well guess what. The genius I am damaged the sheild on the spark plug wire and fried my ignition.
I just happen to have a DL sitting on the bench waiting on me to finish my Ultimate. I put the DL in the Extra and was very suprized to find that the DL right out the box was just as strong as my fully broken in DA.
To make a long story short the DL will have no problem pulling the Extra around with authority. If you really want to make some HP get a tuned pipe.....MTW RE2 or ES Composite. I have tested both on the DL and beleive me that either of the pipes will make the Extra scream like a raped ape.
One other thing about the DL's. Buy your motor from Bob at DL USA. He stands behind his product 120%.
ORIGINAL: T.Edney
Does anyone know the puchout or should i say vertical pullout power with it on the extreme flight 300? I love to fly 3d and just wonted to know if it had enough punch to get u out of trouble if the problem ever occured![sm=punching.gif] Thx for any advise!
Rush,
Can you tell me the header you used with the ES pipe? Manufacturer, model number? What length?
Dave
12" length, 25mm drop KS stainless Steel solid header.
