RE: Aileron servo lead clips?
Well, no it does not make sense. As Ken noted, he has to remove the wing for transport, as most of us do, and then disconnect the servo extensions from the RX. Yeah, the Y connector works if you don't care for independent servo control. But you STILL have to remove something to disconnect the wing from the fuselage and the receiver. Those plastic things Ken pointed out are perfect because they snap in and snap out just as easy.
CGr.
