For an online deal, two really good packages available here:
http://www.thundertiger4u.com/thunde...de-p-7284.html (Trainer 40T with flat bottom airfoil)
http://www.thundertiger4u.com/thunde...e-p-13247.html (Trainer 40H with semisymmetrical airfoil)
The 40T design is similar to a Hobbico Superstar, SIG LT-40, or Hangar 9 Alpha. The 40H design is similar to a Hobbico Avistar or Hangar 9 Arrow
Price $265.99 with free shipping
Airplane with engine and radio. PLUS: fuel pump, glow driver, charger, starting stick, recoil fuel tubing, and fuel cap.
Saturday delivery may be a problem. If any online seller uses FedEx it should be available for a price. I'm cheap so I use "free" shipping whenever possible and it gets here when it gets here. I've left a note for UPS to hold packages at the customer counter, typically when a signature is required, but that means I have to leave work and drive a 30 mile round trip to get the package.
This is a big change from the other thread where you mentioned buying locally. Did one of the hobby shops do something to turn you away?
I think if timing is a factor you should call Mike's, Advantage, and Roy's to see who has what in stock and go from there.
