RCU Forums - View Single Post - Any other to start it?
Old 05-07-2003 | 05:17 AM
lamp3y3
Default Any other to start it?
EZ Start works fine with the Siro after the engine loosens a bit.
As i said before use a heat gun or hair dryer before break in.
After you get it out to the track setting it in the sun should be enough to get it started with the EZ start.
The pull start wont work on a new sirio either unless u heat up the block first.
