RC Monster Trucks Discuss rc monster trucks in this forum
Any other to start it?
Old 05-07-2003 | 01:22 AM
Default Any other to start it?
Can i start my T maxx up if i take off the EZ starter?Oh and one more thing can i get a stater box for it?What eles would start it?
Old 05-07-2003 | 01:29 AM
starter boxes don't work with the t-maxx. You could get a pullstarter for it instead of the auto start. EZ start is the easiest way to start it...why would you want another way to start it?
Old 05-07-2003 | 03:13 AM
when i bought a traxxas is a few years ago the original ez-start was a piece of crap.
i took it off after like day 2 and put a pulls tart on it and have used the same one since.
i heard the ez-start 2 is better but until i see/own one i would say just get the pull start.
Old 05-07-2003 | 04:04 AM
BUGGIES_R_US's Avatar
I dont know. I'm not much of a fan of pull starting a .21 lol
Btw..
How in the hell do you start a sirio if not a pull start?
Those things have so much compression you'd better have a few spare hands standing by. I was pretty sure they dont come with a pull start.
ram
Old 05-07-2003 | 04:48 AM
I thought you can start a sirio with the ez start. It's a direct fit if i'm not wrong.
1. electric start (ez start)
2. pull start
3. drill start
4. starter box
What works best for the sirio and/or other engines?
Old 05-07-2003 | 04:53 AM
Btw..
ram
Use a hairdryer to warm up the crankcase to around 190-200
then it will start After you break it in it wont be a problem.
I had the same problem with the ez start and the new siro. I also decided to replace the ez start with a pull start.
this sirio runs much more reliably and starts very easily compared to the 2.5. ill try .21 conversion after this motor i think. what is the best overall .21 for t maxx ?
2. pull start
3. drill start
4. starter box
You can use the EZ start with the Sirio, but a lot of people have been having problems using the EZ start with the Sirio due to compression. Starter boxes don't work on a T-Maxx. Pull start would probably be the only other option if the EZ start dosn't work with the Sirio. As far as I know, there aren't any drill starts for the Sirio thus far.
Old 05-07-2003 | 05:17 AM
EZ Start works fine with the Siro after the engine loosens a bit.
As i said before use a heat gun or hair dryer before break in.
After you get it out to the track setting it in the sun should be enough to get it started with the EZ start.
The pull start wont work on a new sirio either unless u heat up the block first.
Old 05-07-2003 | 01:06 PM
Banned
Default I think the EZ start works best,
for a stock engine and should work fine for the Siro but if you don't like using the EZ start system you can buy a special shock tower from New Era and then you can use a "Yank eliminator" with a cordless drill. I made one out od a socket and one-way bearing with and extension. and it works great on my .21 and .25!
