Engine choice
All the engines you list will work fine on the plane. See the other threads on this plane for much additional infromation. OS and Saito both have parts readily available. Not sure about the Magnum as there if only one flying locally. Seems to run fine. High end RPM doesn't really tell you anything since the test would need to be made with the same prop and fuel in the same conditions. Good luck.
EXCAP232
