ORIGINAL: buildflycrash
Keep you eye on the fuel level. With a 10oz tank you may get around a 5 minute run.
My older 100 is much better on fuel than the new one I have that is burning close to 2oz per minute.[:'(]
Hayes makes a 13 oz tank that is really good for your setup.
Scott,
Do you run velocity stacks on your 100's? The hunnert on my MoJo 60 has about 15 gallons through it and has a stack. I use an 8 ounce tank and routinely get 10+ minute flights. I will note, however, that my rookie thumbs don't spend much time at high throttle, so I'm sure that is a factor as well.
Anyway, the stack is only about $8 and may give you better fuel economy. Just a thought....
Erik
