ORIGINAL: Vincent
Sandor wrote: <<<Infact it would better if you did.
the P-60 has a very low kerostart voltage needed for the pump.
sometimes it will simply not turn at 0.175>>>
I had this happen a few weeks ago with my Kero start Titan. The pump would prime the fuel and kero start line but would not pump on start up command. I had to swap out the pump at the field. I would imagine this pump would have worked fine with propane start. Can the start voltage be bumped up a bit to get the pump moving better on kero start?? btw the pump had about 150 runs on it.
V..
yes you can , but most of the time it is to much.
you are better of cleaning filters and have the pump cleaned.
you need to talk to Bob W to set this value i think.
i had the same issue with a p-160SE i set it 0.25 higher and all was fine
