Charger "Bling" Ultra Duo 50
RE: Charger "Bling" Ultra Duo 50
Cut and Paste from Graupner website
Operating voltage: 11 ... 15 V / 40 A DC
or 100 ... 240 V AC
mains supply
Charge capacity per output: 1 ... 18 NiMH / NiCd cells
1 ..... 7 LiPo / LiIo / LiMn / LiFe cells
1 ... 6, 12 lead-acid cells
Charge current: 2 x 0.1 A ... 10 A with mains PSU
(total max. 120 W)
2 x 0.1 A ... 10 A with 11 ... 15 V with
DC supply (max. 2 x 180 W or 1 x 250 W)
Discharge current approx. 0.1 ... 10 A (2 x max. 80 W)
Balancer socket: 2 x 1 ... 7 NiMH / NiCd / LiPo / LiIo / LiFe cells
Max. balancer current approx. NiMH / NiCd: 0.1A, LiPo / LiIo / LiFe: 0.3A
Dimensions approx. 230 x 225 x 83 mm
Weight excl. mains lead approx. 2200 g
or 100 ... 240 V AC
mains supply
(total max. 120 W)
Like Geoff says the Wattage is different between mains and 12v/Separate PSU (20-30A).
List price in Europe is 359 euro so more than Mark says by the time it's there.
Dave
Dave
Just got price from here - might be different by the time it gets to UK
http://www.modellbau-bichler.com/ult...ml?language=en
ORIGINAL: Dave Wilshere
We need to find a Jet use for the tyre warmer function! and motor run in feature.
I own several P60's and have sold plenty...none have needed any changes. I think it's more to do with fuel systems
My Feedback: (10)
ORIGINAL: schroedm
your right it is 269,-
if someone pays someone more your ripped off[:-]
My Feedback: (61)
Sandor wrote: <<<Infact it would better if you did.
the P-60 has a very low kerostart voltage needed for the pump.
sometimes it will simply not turn at 0.175>>>
I had this happen a few weeks ago with my Kero start Titan. The pump would prime the fuel and kero start line but would not pump on start up command. I had to swap out the pump at the field. I would imagine this pump would have worked fine with propane start. Can the start voltage be bumped up a bit to get the pump moving better on kero start?? btw the pump had about 150 runs on it.
V..
V..
My Feedback: (10)
ORIGINAL: Vincent
V..
V..
yes you can , but most of the time it is to much.
you are better of cleaning filters and have the pump cleaned.
you need to talk to Bob W to set this value i think.
i had the same issue with a p-160SE i set it 0.25 higher and all was fine
