RCU Forums - View Single Post - Aileron servo lead clips?
Old 05-21-2008 | 01:32 PM
2slow2matter
Default RE: Aileron servo lead clips?
Alright,
Sometimes you read something and no matter what, you just can't see anything other than what you want to see.
For whatever reason, I thought we were talking about a plug in winglike, say, a midwing design where there was a servo in each wing, and you needed an extension to get out to the root of the wing.
So, now I understand what you are talking about. Apparently, there is something in a screen name....[&o]
Since you have one servo only, sitting in the middle of your wing, then it is simple. You do not have nor need to tape the connections together.
Sorry for the confusion guys. Sometimes I'm just too tired to "get it."
I hope this helps.
So, to recap, don't worry about all of that other gibberish right now. you do not need to worry about securing the connection together. If in fact you do want to, then yestape or the clip is the only way to go, but I really think you are wasting time and money. The only connections that I secure are those that I cannot see, and do not disconnect and re-connect everytime I fly. That is why I use heat shrink. Your connection is no more likely to come apart than the connection at the rx.
