RCU Forums - View Single Post - Making Dubro Spinner fit with prop
Old 05-21-2008 | 02:39 PM
ser00
Default Making Dubro Spinner fit with prop
Hi everybody,
I have a quick question. I have several planes that I would like to place Du Bro nylon spinners on (2.25, 2.5 and 2.75 inch). I use APC props (11x6) and I notice that the spinner will not seat on the back plate because the prop hole on the spinner does not match the profile of the root. How do I make the spinner and prop play nice with each other? Do I take out the Dremel and cut on the spinner to make the prop fix properly? Also, would a master airscrew prop with the spinner with modification to the spinner? My main concern is that if I do not make exact cuts on both sides of the spinner, then the spinner will be out of balance and the engines will wear out faster. Any suggestions? Thanks!
