RCU Forums - View Single Post - feathuring shaft
Old 05-22-2008 | 04:06 AM
shizack
Default RE: feathuring shaft
Put a nut driver or whatever tool you use to remove the nut or bolt into one side ONLY and turn it. If one of the blade grips moves at all then you definitely have a bent spindle.
The only way to know for sure is to remove it and check it with a straightedge or roll it on a sheet of glass.
