RCU Forums - View Single Post - engine dissasembly
Old 05-22-2008 | 05:54 AM
snowbl!nd's Avatar
snowbl!nd
Default RE: engine dissasembly
Welcome to the forum youngwarrior
You'll have to remove the cooling head and sleeve first - this will give you some movement in the piston & con-rod, allowing it to slide off the crank pin. Once that lot is out of the way only the crankshaft will remain, which should slide out with a firm tap.
