RCU Forums - View Single Post - Sig Kadet Senior Aileron modification
Old 05-22-2008 | 07:59 AM
Dsegal
Default RE: Sig Kadet Senior Aileron modification
If you add ailerons be sure to reduce the dihedral by one-half the specified amount. There is nothing easy about the task you have in mind if you do have not kit-bashing experience and are not comfortable with re-engineering the wing. If you must have ailerons consider a kit that comes with them.
