RCU Forums - View Single Post - CA Widebody 60 Tank Support
Old 05-22-2008 | 09:20 AM
rwlewis
Default RE: CA Widebody 60 Tank Support
When I built my WB60, I put the tank back over the CG by cutting throught he cockpit floor and mounting it over the wing. I painted the canopy silver (inside) to hide it. Never have understood a clear canopy on a pattern plane anyway...
I also remember being quite perturbed that the motor mount C/L was not marked on the firewall. I made a flat balsa piece representingt the drive washer, lug spacing, and prop shaft using the dimensions of the motor (YS110) and attached it to the motor mount. I stood the plane on its rudder post, placed the mount with the motor representation attached, then slid the cowl on and taped it in place where it looked correct. Then I moved the mount around until I knew the prop shaft would be in the center of the cowl opening. I removed the cowl and mark the motor mount location on the firewall.
Richard
