RE: 1000mah NiMH 2.2 oz OK For Pattern ?
You should have no problems with that setup. Just be aware of your voltages. Make sure you check your voltages regularly and learn how quickly it'll drop off. Depending on your engine choice you'll get more or less flights per charge,
Arch
