RCU Forums - View Single Post - engine dissasembly
Old 05-23-2008 | 07:00 AM
iamnot
Default RE: engine dissasembly
to remove a tight sleeve
piston at bdc
insert a thick zip-tie or popsicle stick
into the exhaust port
rotate piston up
that should push the sleeve up
enough to grasp it
be very careful of using a screw driver
to push the sleeve out
one slip easily equals
ruined sleeve
also, your broken bit may just tap out
once you can get to the parts
