RCU Forums - View Single Post - Elect. ignition for Poulan 25cc?
Old 05-23-2008 | 10:40 AM
  #58
JIMARRINGTON
Default RE: Elect. ignition for Poulan 25cc?
I noticed last night that the setup I have to hold the sensor in place is not working out too good. The sensor I used has the output wire coming out of the top. I ran the clamp over the top of the wire to hold the sensor. Now the clamp has rubbed the insulation off the wire and is shorting out the sensor. I put electrical tape over it but not a good solution. I need to find some way to mount the sensor to the clamp from the outside. I have thought of using epoxy to mount it. I can always adjust the timing just by moving the clamp. But was wondering if you guys thought the epoxy would be strong enough to hold the sensor to the clamp. Or if you guys have another idea.
Jim
