RCU Forums - View Single Post - CC BEC causing interference or damaged?
Old 05-23-2008 | 12:42 PM
VulcanGrey
Default RE: CC BEC causing interference or damaged?
Did you remove the red wire from the ESC to the RX as the CC BEC instructions show?
If you did not, try that.
If you did, try putting it back in. Some ESC's need the red wire going to the RX to function properly.
