RE: CC BEC causing interference or damaged?
I called CC and the rep told me to remove the signal wire from the BEC. However, it did not solve my problem.
The funny thing is, I don't even need a BEC. I was going to switch to Deans connector, so I decided to solder the BEC at the same time. I thought I would be needing it in the future when I upgrade the servos.
