RE: DL-50 engine
I've replaced mine with a spring from a hardware store. It was labeled as a #11. The spring doesn't need to be an exact replacement, as long as it maintains solid contact between the plug cap and the plug. I recommend using an ohm-meter to check for connection between the ignition box and the head of the engine with the engine running to ensure the spring is doing it's job.
