Carb Problem On My Gas Engine
Your thoughts are most likely correct. Cut the tube off at an angle. Start out with the cut down side facing the front but you may have to turn it some one way or the other to finally achieve your goal.
If you continue to have trouble, two cycle gas engines when unloaded will often break into 4 cycle. You could try leaning your mixture some and/or changing prop size.
Good luck,
Jim
