ORIGINAL: vnmsgt
ORIGINAL: ecocav04
i bought the non evo verson on a very smooth track with small jumps it should rock on a rough rutted track it failed pretty bad the shocks are short and it restrics alot of droop. get the evo kit on it spend a little bit of time setting it up and have a go and there 2 worlds apart
oh I thought you meant the caster. I have 2 evo kits right now that are new and they look identical except for the shock towers, front drive cups, and that is it. The shocks look the same and everything else. Maybe the previous owner changed some stuff over already.
you have 2 kaos dt 19 kits one is the evo the other isnt. the shocks look the same but one has blue springs and one has white the blue spring shocks are alot longer then the regular ones and the shocktower location playsthe biggest role in the handeling of the car
