RCU Forums - View Single Post - Starting Problems
Old 05-24-2008 | 08:48 PM
DavidAgar's Avatar
DavidAgar
My Feedback: (108)
Default RE: Starting Problems
If you can see the fuel getting into the carb you can open up the trottle to full power, hold your finger over the carb and prop the engine a couple of times. This will pull the fuel into the engine. You are of course doing this without the glow plug igniter being installed. Once you have done this, reduce your power setting to just a bit over idle, install your glow plug igniter and flip the prop with your chicken stick. Good Luck, Dave
